Accudry Whirlpool dryer
How do I locate and change the heating element?
It is in the rear of the machine after removing the 1/4" screws. The heater is held in by 2-1/4" screws. If your dryer is isn’t heating you should check the thermal fuse and all t-stats first with an ohmmeter also check for L1-120v L2-120v and L1&L2-240.
