Accubake oven
The broiler element exploded near the plug at the back of the oven. I have purchased and installed a new element. I’m am getting no power to the broiler element. Any ideas on what the problem could be.
Thanks,
Mase
Replacement parts for WHIRLPOOL RBS245PDS17 24" Built - in Electric Single Oven Self - Clean | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf
If both broil and bake do not come on then the Thermostat Item 37 i Section 1 may be open.
If it is just the broil element then unfortunately it is probably the control board.
I would check the wiring to the broil element just to be sure that a wire has not burned off.
