Accessing the Belt and Idler
I need to replace the belt and idler pulley. Maybe the front and rear drum seals while I’m at it.
I assume I access the pulley and belt through the bottom, but how do I wrap the belt around the top of the drum? I removed the rear cover but that did not expose the drum. Do I remove the top as well and if so, how?
Finally, where can I find instructions of replacing/accessing the drum seals?
Well I see now that there is no access from the bottom. It looks like I’ll have to remove the bulkhead. I’m a little leary because I don’t know just what that entails. :eek:
Do I have to remove the Lint Chute Assembly and the “Box” before the bulkhead will come off or can I remove the bulkhead without taking those parts off?
Do I need to tag and disconnect all the sensor connectors or is there a main connector somewhere that I can disconnect?
Surely somebody must know…
