I have removed the decorative trim panel but even after removing three screws the vents panel won’t come out to allow the drawer to get access to the compressor.
How do I get this panel out ?
Cc
Cc
Without being there hard to say but the following may help
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003670900.PDF
If lifting it up and out does not work try to the laft and to the right.
On page 10 the front view shows the top panel which I have removed , the vents which I can’t seem to remove
at all are shown but not as tall. They feel stuck and wont go up - down - left or right and I cant find more screws.
Seem to be glued to the panel below which is where the light switches are for both sides.
Chris
Sorry but I cannot be of any help.
Perhaps the install was not the same as in the instructions.
You could try to run a thin knife between the panels to see if they are glued together.
Installers sometimes do do strange things.
If they are not glued in place then you may just have to use more muscle.
Perhaps a block of wood, some cloth to protect the surface and a hammer.
You could also call in a pro.
