Hi
I have a maytag stackable maytag washer/dryer. washer model lse7806ace.
I ordered part #A4026239 water inlet valve for my maytag stackable washer.
How do I access the back of the washer. Does the washing machine come out separately from the dryer.
Is there enough play(slack) in the water,electric & drain lines to allow me to pull out the washer?
How do I install the water inlet valve for the washer.Is there electric involved?
Any other installation details would be appreciated.
I also ordered part #AP4026952 washer timer, can you give me installation details on how to install it.
Thank You,
HAPPY HOILIDAYS
Jay Wolstoff
wolstoff@optonline.net
You can access the water valve by removing the access panel (#21 on the diagram) and the washer front panel. The washer can be pulled out of the stand as well.
There is a screw on the bottom of each of the control panel end cap. Unscrew them until the control panel will come down enough to release it from the slots in the dryer front panel.
Here are the breakdown diagrams and Replacement parts for MAYTAG LSE7806ACE Stacked Laundry - Ele | AppliancePartsPros.com
