Does anyone know where one can get real Whirlpool elec range drip bowls? I’ve tried ordering from two different on-line companies now and they send me generic parts that I can get at Loews or Home Depot, but they don’t fit. This Whirlpool has drip-bowls and trim-rings for two 6" and two 8" elements. I was able to get 6" diameter bowls and rings that were EXACT replacements from A-1 Appliance Parts. However, the 8" bowls and rings lacked a critical cut-out on the horizontal portion of the bowl’s lip at about the 6 o’clock position (assuming the element connector is at 12 o’clock).
Appliance Parts Pro said they had Whirlpool parts and the picture they showed on-line was the correct bowl, but the parts they sent me were the same generic replacements from FSP that lack the cut-out. The rings did have the cut-outs, but the bowls didn’t. Without the cut-out the bowl and ring will not lie flat on the range top, because a spring clip that holds the element in place is in the way.
Go to partstore DOT COM
and look for your model number.. etc.. i found the “drip bowls” for my whirlpool electric range their.. found my model number in the drawer underneath the cooktop where you would store cookie sheets, pans etc…
good luck Grant
