6 gas burner
the gas valve is bad cannot find valve anywhere part#82478 decor said they cannot get the part im wondering if there is replacement part or is there any other alternative there is a small leak only in one valve the stove works great i cant afford a new stove need to fix this one this stove is around 19 years old all black if there is any other info you need let me know
Does this gas burner valve leak while in use or it does it all the time?
If it does it only while in use then just do not use it.
If it does it all the time then I would try to fix the leak with an epoxy glue and live with the rest of the burners.
