Brand: Samsung Model Number: RS265TDRS/XXA s/n: JJ8K4GBB701380E Main Symptom: Recurring error code, came back after cancelling, no frost in inside of refrigerator section. Operation and temperature seem normal. What happens & when: No other symptoms that the code. Code returned a couple of days after cancelling the first time.
Error Code (if any): 5E
5 E
Refrigerator evaporator defrost temperature sensor failure.
Unplug the refrigerator and check the wire harness connection on the refrigerator evaporator defrost temperature sensor. Reconnect the refrigerator evaporator defrost temperature sensor wire harness if it’s loose. If the wire harness connection is okay, check sensor resistance using a multimeter. The meter should measure about 5,600 ohms if the sensor temperature is 72 degrees (room temperature) and 13,290 ohms at 32 degrees. Replace the temperature sensor if resistance is off by more than 10 percent. If sensor resistance is okay, reinstall the temperature sensor and check the sensor’s wire harness connections to the electronic control board (purple wire and gray wire on CN40). Reconnect the wires if loose. If the wire connections are okay, disconnect the sensor wires from the electronic control board and measure resistance through the sensor’s wires. The meter should read the same resistance as for the temperature sensor. If the meter measures correct sensor resistance through the wires, you’ll likely need to replace the electronic control board because it’s not accurately detecting sensor resistance. Find and repair the sensor wiring failure if the meter measures infinite resistance through the sensor wires.
Refrigerator evaporator defrost temperature sensor, Electronic control board.
5 E
Unplug the refrigerator and check the wire harness connection on the refrigerator evaporator defrost temperature sensor. Reconnect the wire harness if it’s loose. If the wire harness connection is okay, check sensor resistance using a multimeter. The meter should measure about 5,600 ohms if the sensor temperature is 72 degrees (room temperature) and 13,290 ohms at 32 degrees. Replace the temperature sensor if resistance is off by more than 10 percent. If sensor resistance is okay, reinstall the temperature sensor and check the sensor’s wire harness connections to the electronic control board (purple and gray wires on CN30). Reconnect the wires if loose. If the wire connections are okay, disconnect the sensor wires from the electronic control board and measure resistance through the sensor’s wires. The meter should read the same resistance as for the temperature sensor. If the meter measures correct sensor resistance through the wires, you’ll likely need to replace the electronic control board because it’s not accurately detecting sensor resistance. Find and repair the sensor wiring failure if the meter measures infinite resistance through the sensor wires.
