4-Cycle 2 Speed Conservator Washer
Hello my problem is we have a washer that spinsout on the first spin but not the final spin whats the problem Sam out of Sparta IL.
We have tried everything and havenot came up with a solution to solve this problem we need some help.
Sam,
Does it fill up with water for the rinse cycle?
Does the timer go all the way to “off” position?
:slight_smile: Hello Gene yes it does both of what you mentioned it fills all the way up and it turns completely off we just dont know whats the problem.
Open the control panel and bypass the lid switch. Run it again. If the switch is not the issue then I would suspect the timer.
Here are the break down diagrams and Replacement parts for WHIRLPOOL CAWB427JQ1 | AppliancePartsPros.com
