2015 Bosch Silence Plus E25 error
Brand: Bosch
Model Number: SHE3AR76UC/27
Main Symptom: Not draining
What happens & when: Mid cycle the machine shows E25 error. Both the machine drain line, main drain hose to garbage disposal are totally clear. Impeller is free, turbidity sensor clean, I removed the pump motor, I get 126 ohms resistance between any 3 terminals. Is this normal or do I need a new pump? I dont see anything in the filter assembly either.
When I manually add water and lift the float, there is a strong reaction of the pump, causes a nice whirlpool in the basin like its going to drain but then stops. If I do this too many times it throws an E15 code for leaking.
Help!
Error Code E25
Parts or tests already tried: Pump resistance 126 ohms, turbidity sensor clean. Drain hoses free, been working fine other than a few E25 codes over the years that Ive been able to clear.
E:25 error code maybe caused by loose drain pump covers.
Bosch Dishwasher E25 E24 Error Code Service Bulletin 58300000150815.pdf (91.0 KB)
Mine was snapped cleanly in place. Good to know however.
I called a Bosch dishwasher phone number 800-444-9091 and I was supposed to have an account number since I think technicians use this line, however the person I spoke to said the motor for my dishwasher should be between 80 and 120 ohms. Mine is 126 and he said yeah that should work. I put everything back together, and poured some super hot bleach water down the drain line to a bucket to clean it out. Took the water as fast as I could pour it in, very little came out, some bits of sand which surprised me and some grease film residue.
Hooked everything back up and seems to finish the cycle now.
