Bought a side by side fridge for the garage and was told it worked. I cleaned it up and thoroughly vacuumed the coils, around the compressor, etc. The freezer and fridge sides are both at good temperatures but the dividing wall between them is 119-120 degrees on the front. Anyone have thoughts on the cause or fix? I found a date of 2000 for the manufacture. I would assume the system is closed but it seems plausible some contaminate has blocked those part of the lines and it is over heating in that area.
[QUOTE=Dinan540iS6MT;909117]Bought a side by side fridge for the garage and was told it worked. I cleaned it up and thoroughly vacuumed the coils, around the compressor, etc. The freezer and fridge sides are both at good temperatures but the dividing wall between them is 119-120 degrees on the front. Anyone have thoughts on the cause or fix? I found a date of 2000 for the manufacture. I would assume the system is closed but it seems plausible some contaminate has blocked those part of the lines and it is over heating in that area.[/QUOTE]
Without the heater strip that space between the doors will sweat and cause water on the floor and rust on the appliance.
This is normal I think
