1 elect. burner only works on high
The large elect. element on the stove top sparked and tripped a breaker while boiling a large pot of water.
I found the short was the old burner, but when i plug in a new burner element it will only come on high no matter what the dial is set at.
All the other burners work fine.
Any suggestions?
Brad C
[quote=btc;114192]the large elect. element on the stove top sparked and tripped a breaker while boiling a large pot of water.
i found the short was the old burner, but when i plug in a new burner element it will only come on high no matter what the dial is set at.
all the other burners work fine.
any suggestions?
brad c[/quote]
brad, you need to replace that burner switch, and that will do it. tom
