Dave W.
#1 Posted : Monday, June 7, 2010 10:59:53 AM(UTC)
Dave W.
The washer completes the wash cycle, drains the wash water and refills with rinse water, then stops. It will not tumble the rinse water, nor drain it - nothing happens. At the point when everything stops, both red lights on the control panel flash. The pump works fine draining the wash water and I replaced the motor brushes. Ideas?
ooeygooey
#2 Posted : Thursday, June 17, 2010 12:01:07 PM(UTC)
ooeygooey
I have the same model, and it's doing the same thing. Nothing is in the drain pump. How can I fix this?
EVERAM
#3 Posted : Thursday, June 17, 2010 3:09:14 PM(UTC)
EVERAM
Well, I have the same problem, my keymore washer do the cycle, drains and refill then stop, I have to turn the dial all the way to where stop and then finish the wash, anyone has an idea of what could be the problem?
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
GE washer stops mid cycle (Washer Repair)
by APPLIANCEDUDE1972 3/4/2015 6:32:45 AM(UTC)
Dishwasher stops mid cycle (Dishwasher Repair)
by vpchianese 11/15/2013 2:32:24 PM(UTC)
Maytag washer stops mid cycle (Washer Repair)
by paubert03 12/2/2012 3:33:21 PM(UTC)
by dideyjohn 11/27/2012 6:06:54 PM(UTC)
by tedwards353 2/20/2012 10:21:16 AM(UTC)
by maryprice4 10/17/2011 6:29:09 PM(UTC)
by ncdunn 3/31/2011 6:55:03 PM(UTC)
by krislinda 11/9/2010 12:52:34 PM(UTC)
Whirlpool Washer Stops Mid Cycle (Washer Repair)
by cfphillips 9/3/2010 11:01:15 AM(UTC)
Maytag SE 1000 washer stops mid cycle or won't start wash cycle (Washer Repair)
by katyat 9/10/2009 1:23:57 PM(UTC)
by CLK 7/19/2009 11:03:25 PM(UTC)
Frigidaire diswasher stops mid cycle (Dishwasher Repair)
by bhacker 7/17/2009 3:58:44 AM(UTC)
Whirlpool washer stops mid cycle (Washer Repair)
by kgundi 6/5/2009 7:39:39 AM(UTC)
