JolieBlonde
#1 Posted : Monday, June 7, 2010 9:50:26 AM(UTC)
JolieBlonde
Following a self-cleaning cycle, the oven doesn't heat. Neither the top or bottom element heats up at all. The electronic display, timer, oven light, etc., all work just fine. Is there a fix I can do myself? Thanks!
#2 Posted : Wednesday, June 9, 2010 5:06:44 AM(UTC)
Replacement parts for WHIRLPOOL RBS275PDQ11 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204451884.pdf
First tru flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
If that does nothing it would be a good idea to check the voltage (240 volts) at the oven.
Could be the hi-limit thermostat (Item 37 in Section 1) is open.
Check it with meter for 0 ohms.
Be sure to kill the power to the un it when doing this.
Be very careful when working on the unit, 240 volts is lethal.
