Miken47
#1 Posted : 15 years ago
Miken47
Maytag Electric Double Oven Model CWE5800ACE. Top oven will not heat. Control pan and clock seem to be working and temperature can be set but oven does not heat. The lower over works fine.
#2 Posted : 15 years ago
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG CWE5800ACE Walloven - S/c Ele | AppliancePartsPros.com
This may come in handy.
http://www.servicematters.com/maytag_library/docs/16000082.pdf
Could be that the hi-limit thermostat is open (limit switch) Item 25 in Section 1 (I think).
Upper Maytag oven won't heat (Oven Repair (including Ranges and Cooktops))
by tfuertes 13 years ago
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 13 years ago
by easye 14 years ago
Maytag oven won't heat up (Oven Repair (including Ranges and Cooktops))
by steelerfan349 14 years ago
Maytag Oven Won't Heat After Self Clean Cycle (Oven Repair (including Ranges and Cooktops))
by blindab 15 years ago
maytag oven won't heat (Oven Repair (including Ranges and Cooktops))
by blonda1972 16 years ago
