Dishwasher soap dispencer does not open on right time whcih leaves soap in the dispencer even after the cycle is complete. Help1
How did you determine that it is not opening at the right time?
Or are you just assuming that it did not open at the right time because there is soap left in the dispenser.
Soap left in the dispenser is usually: 1. Low water fill - often the filter screen on the input side of the water valve needs cleaning. 2. Dirty filters in the pump are impeding water flow. |
THIS FORUM IS DEAD!!!!!!! |
