The control knobs on my cooktop have frozen, can't push them in. Do I need to replace the whole stem, or can I just replace the valve switch?
Originally Posted by: dsm@davidmenkes.com ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The control knobs on my cooktop have frozen, can't push them in. Do I need to replace the whole stem, or can I just replace the valve switch? Please explain..
The cause of the problem is a stuck middle cone inside the gas burner valve. Correction is to replace such gas burner valve. Here are the break down diagrams for the Jenn Air stove Model JGD8130ADBGene.
