Dale Wolverton
#1 Posted : Friday, June 4, 2010 10:21:38 AM(UTC)
Dale Wolverton
This is a side by side unit. The area between the freezer & refrigerator, where the doors contact, is so hot that it will burn you. I am supprized that it has not melted the rubber on the magnetic strip. It is not warm anywhere else & is still making Ice. Is there a heater strip here? I thought that the defrost timer had went bad so I turned it. It has not made a differance. What can it be?
#2 Posted : Friday, June 4, 2010 10:45:24 AM(UTC)
Replacement parts for WHIRLPOOL RS25AGXNQ00 Refrigerator | AppliancePartsPros.com
The most common cause is dirty condenser coils or the condenser/compressor fan is not operating correctly, see section 10.
Dale Wolverton
#3 Posted : Friday, June 4, 2010 11:53:20 AM(UTC)
Dale Wolverton
Originally Posted by: denman Go to Quoted Post
Thank You, I clean them and see what happens
Dale
Dale Wolverton
#4 Posted : Tuesday, June 8, 2010 8:32:14 AM(UTC)
Dale Wolverton
Thank You for the help,
The coils were very dirty. looked solid, I blew and vacumed them and I think this has fixed the problem.
Refrigerators in the cold (General Talk)
by Hanak 11/1/2019 4:59:02 AM(UTC)
my refrigerators lights flash off and on (Refrigerator & Freezer Repair)
by microsoftuserman11 8/1/2014 8:35:33 PM(UTC)
Two refrigerators down in a month (Refrigerator & Freezer Repair)
by Frostd Flakez 4/5/2011 6:55:19 PM(UTC)
Motor Nameplate Info for Small Refrigerators (Refrigerator & Freezer Repair)
by TomThumb 4/27/2010 5:21:09 PM(UTC)
Maytag Expands Recall of Refrigerators Due to Fire Hazard (Refrigerator & Freezer Repair)
by Gene 8/26/2009 11:57:58 AM(UTC)
Repairing Stainless Steel on Refrigerators (Refrigerator & Freezer Repair)
by joeb 1/13/2009 12:34:14 PM(UTC)
GE refrigerators (GS* & PS* models), the evaporator fan motor test and replacement. (Refrigerator & Freezer Repair)
by Gene 1/8/2008 6:15:10 PM(UTC)
