DEMENTED1
#1 Posted : Friday, June 4, 2010 9:39:53 AM(UTC)
DEMENTED1
Can You Please Tell Me Where The Heating Fillament Is At Or The Cutoff Switch. Everything Is Turning And Blowing Fine, It Just Wont Get Hot At All!!!!!!!! Any Help Will Be Greatly Appreciated Also If You Have A Number Where I Can Get Them At As Well Will Be Awesome.
#2 Posted : Saturday, June 5, 2010 2:07:25 AM(UTC)
A Model Number may help others help you.
Ken more does not actually make anything so the unit could be from just about any manufacturer.
First thing to check is that you have 240 volts.
Sometimes you can loose half the line without tripping the breaker.
This will result in no heat.
Try switching the breaker off/on slowly a couple times.
If this does nothing then measure the voltage at the plug (L1 to L2)
If OK check for voltage at the unit's terminal strip.
[COLOR="Red"]Be careful, 240 volts is lethal!!![/COLOR]
DEMENTED1
#3 Posted : Saturday, June 5, 2010 9:53:07 AM(UTC)
DEMENTED1
Awesome! Thanks! Im Goin To Check That Out Right Now! Sorry About The Model # Didnt Think About It. But I Will Get One To You Today.
DEMENTED1
#4 Posted : Wednesday, June 9, 2010 12:42:56 PM(UTC)
DEMENTED1
Hey Sir I Do Have 240 At Both. Where Would I Be Able To Find The Model Number At!
#5 Posted : Wednesday, June 9, 2010 5:07:31 PM(UTC)
Not sure where they would hide it.
This may help
Model Number Locator
Too bad they do not have a stackable category
