karl d Scheumann
#1 Posted : Monday, July 14, 2008 8:25:53 AM(UTC)
karl d Scheumann
The oven temp will not go above 200 degrees. Why. The burner is lite and burning, but very little heat. I smell gas. Please help.. Karl
karl d Scheumann
#2 Posted : Monday, July 14, 2008 11:44:10 AM(UTC)
karl d Scheumann
I just check the oven and the broiler works but the oven does NOT lite up. I left it on for several minutes and the oven didn't lite. What need replaced??
#3 Posted : Monday, July 14, 2008 12:22:10 PM(UTC)
Hi Karl,
Most likely the problem is a bad bake igniter, but before replace it I would check the igniter for continuity. If it's open then no doubt this part has to be replaced.
- The part number for the bake igniter is AP2934763
Here are the break down diagrams for the Caloric range Model RST359
How to go about fixing my '79 Caloric range (Oven Repair (including Ranges and Cooktops))
by TrevorS 2/6/2013 5:12:44 PM(UTC)
Caloric Range - Dead Short in Burner Spark Switch (Oven Repair (including Ranges and Cooktops))
by Mark_F 10/4/2010 6:31:33 AM(UTC)
Caloric Range Heritage Series (Oven Repair (including Ranges and Cooktops))
by stupidcupid58 6/12/2009 8:39:56 AM(UTC)
What part do I need for a Caloric Range? (Oven Repair (including Ranges and Cooktops))
by bvaughan 4/7/2008 3:40:46 PM(UTC)
Caloric Range/oven (Oven Repair (including Ranges and Cooktops))
by Nedi 11/22/2007 2:17:53 PM(UTC)
