:( checked all hoses and connections to tub - took water pump apart and checked it - machine sometimes still will not drain - after shutting it off for a while it will usually drain -
Originally Posted by: keithbrent ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) :( checked all hoses and connections to tub - took water pump apart and checked it - machine sometimes still will not drain - after shutting it off for a while it will usually drain - Check the wire harness and its connections between the main power board (inverter - #60 on the diagram) and the drain pump. If there is nothing wrong, replace the main power board. - The main power board Part number: AP3204590
