hi all by the way very good site here's my problem,just bougth used washer & dryer just change rear drum bearing assembly on dryer i found a spring on the botom with dust while cleaning it see attach photo,don't know where it goees works well for 5 min then stops & restart open door to check ,it stops good close door ,restart but won't engage,can hear a biz sound on the board and the heat element starts roll the drum with hands it engage ok any helps would be appreciated dede2854 attached the following image(s):
