cwarren@nehp.net
#1 Posted : Wednesday, June 2, 2010 2:18:21 PM(UTC)
cwarren@nehp.net
The cook surface switch on the left front (controls left rear surface) shorted out and melted. I removed this module and taped up the wires, but the other three surfaces will not come on. I would like to know if they depend on this unit for power? The other modules look like new, but I don't have a schematic and can't tell where they get the power from.
#2 Posted : Wednesday, June 2, 2010 8:04:15 PM(UTC)
According to the Tech sheet, very likely the shorted switch damaged the power board.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KESA907PSS01 30" Slide - in Electric Oven Convection | AppliancePartsPros.com
cwarren@nehp.net
#3 Posted : Thursday, June 3, 2010 7:58:16 AM(UTC)
cwarren@nehp.net
Does the power board also provide input to the oven? The oven works.
Thanks, C Warren
#4 Posted : Thursday, June 3, 2010 10:41:10 PM(UTC)
Yes, there is one power board for everything.
cwarren@nehp.net
#5 Posted : Friday, June 4, 2010 11:35:06 AM(UTC)
cwarren@nehp.net
Why would the over work and the other three elements not work it one control board provides power for both?
#6 Posted : Friday, June 4, 2010 5:47:21 PM(UTC)
Control board has over a hundred different parts which control different parts of the range. Check out the wiring diagram in the Tech sheet.
