I opened a cupboard door and an insulated mug fell out on the glass top of my Maytag Gemini and cracked it! I can't believe it :eek: Is there a replacement available? Is this a costly fix? Can we do this ourselves without having to call someone in?
I wanted to change someday to stainless, but not yet...
Thanks for any help...
Rank: Administration
Groups: Guests
Ouch! It's not a complicated repair. Make sure to unplug the range first! The glass comes as one piece with the frame. There are screws holding it down in the front and back. See #4 on this diagram. There are three colors available, I think what you need is the white one - Top, main (wht). The top is currently out of stock, if ordered you can expect to get it within a week or two.
Yes, it is white. Can you estimate an appoximate cost? Thanks so much!
Groups: Guests
$223.32 for the top. Lowest shipping is $4.95, there is no extra charge due to size... Here is a direct link. To place an order, click on ADD TO CART and finish the order. We'll take it from there.
