unluckygeowner
#1 Posted : Saturday, July 12, 2008 12:02:40 PM(UTC)
unluckygeowner
The ice dispensor and water dispensor on my GE GSH22JSRE fridge stopped working a little while ago and doesn't crush, dispense cubes, or water when you press the lever on the door. Here are the details.
- Ice maker works fine and fills the tray with cubes
- When you press the door lever (in crush, cube, or water mode), the LED light goes out for about 2-3 seconds, but the motor doesn't start. In the background I hear a click (the relay kicking in?) and then a noise that is best discribed like your stomach rumbling (low intenstity).
- If I open the freezer door and depress the light button and try the lever the same thing happens as when the door is normally close.
- If I remove the ice tray, I can manually turn the motor so that isn't stuck.
- I can manually spin the augor to get cubes out so that isn't the issue.
Any ideas? Is the motor itself bad?
jpjet
#2 Posted : Tuesday, July 15, 2008 7:57:42 AM(UTC)
jpjet
I have the same problem. I think it need the circuitboard on the back replaced, but Im still testing.
abadfish66
#3 Posted : Tuesday, July 15, 2008 8:30:08 AM(UTC)
abadfish66
Your main control board is bad, located on the back of the refer behind an access panel
unluckygeowner
#4 Posted : Friday, July 25, 2008 1:17:41 PM(UTC)
unluckygeowner
Just to close the loop - The replacement main board arrived and it fixed the issue. Thank you to all the folks who responded.
