SCOTT MASKE
#1 Posted : Tuesday, June 1, 2010 5:26:55 PM(UTC)
SCOTT MASKE
When I Went To Use It Today, Will Not Start. Has 2 Green Flashing Lights On The Front. One Is Flashing Rinse Only. The Other Flashing Light Is Cancel/drain, However It Will Not Cancel, Will Not Reset And Will Not Restart.
#2 Posted : Wednesday, June 2, 2010 3:01:51 AM(UTC)
Replacement parts for WHIRLPOOL KUDM01TJBS0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
Read through the tech sheet and try the diagnostics.
Could be the control board or the control panel.
Often flashing lights indicate a stuck (always closed) key switch.
The usual way to trouble shoot is to check the key switches on the control pane (keypad) with a meter. If it checks out OK then it is probably the control board.
It is still abit of a crap shoot but your odds are better.
Kitchenaide Diswasher Not Draining (Dishwasher Repair)
by rm08780 1/31/2012 5:02:09 AM(UTC)
Kitchenaide Diswasher (Dishwasher Repair)
by SCOTT MASKE 6/1/2010 5:26:17 PM(UTC)
