Joe Metzger
#1 Posted : Tuesday, June 1, 2010 4:22:47 PM(UTC)
Joe Metzger
My Maytag Refridgerator did not auto defrost. Model MZD2766GEB. Resistancs on heat element when frozen was 22 ohm both straight thru element and thru what I believe is the temp sensor and element. When I defrosted with hair dryer I had 22 ohm thru element and 240k ohm thru element and sensor. Not sure if element is bad or the defrost cycle timer is bad. Please advise. Thanks
#2 Posted : Wednesday, June 2, 2010 1:28:05 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MZD2766GEB Ref - SXS/I&W | AppliancePartsPros.com
The defrost heater and thermostat check out OK so it is probably your defrost board that is shot (Item 13 in Section 2).
well water minerals clogged auto defrost drain (Refrigerator & Freezer Repair)
by preisbeck 2/18/2013 8:50:58 AM(UTC)
Auto defrost control replacement problem (Refrigerator & Freezer Repair)
by brewii 7/8/2011 10:33:08 AM(UTC)
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 6/30/2009 6:05:59 AM(UTC)
