BrianA1
#1 Posted : Tuesday, June 1, 2010 12:23:02 PM(UTC)
BrianA1
I was wondering if maybe the thermostat has died. The freezer stays at 48 degrees. Been that way for about a week.
Brian A
#2 Posted : Wednesday, June 2, 2010 1:33:42 AM(UTC)
Could be, if the unit seems to cycle normally re: compressor turning on/off.
You could check this by unplugging the unit, shorting the contacts on the thermostat, plug it in and give it a try.
If the temperature drops below the 48 degrees, then the thermostat is the problem.
