I have removed and disconnected the icemaker module. I have current at the power connector, however no continuity through the motor itself in any testing combination. Since this is a 120v motor, seems like I should have continuity thru the windings at least, but not sure. Where can I find the test diagnosis procedure for this motor? Thanks in advance for your assistance, Jon
