2 Pages12>
TurtleCove
#1 Posted : Monday, May 31, 2010 8:19:08 PM(UTC)
TurtleCove
I turned the wheel insiide the fridge to zero, to turn it off, to clean it.
After cleaning, I turned it back to 7. As I turn the wheel, at about 2 I hear the compressor kick in. I also feel air blowing inside from the fan.
However, it never cools. Single door model, with no freezer.
Where do I start with this?
#2 Posted : Tuesday, June 1, 2010 2:39:49 AM(UTC)
Did you poke a hole in the evaporator.
TurtleCove
#3 Posted : Tuesday, June 1, 2010 1:45:26 PM(UTC)
TurtleCove
Seriously...all I did was turn the wheel off to clean it, and now it won't cool. Never moved it, or poked around on anything.
What's the evaporator? And, I'd know if I "poked a hole in it", wouldn't i?
TurtleCove
#4 Posted : Tuesday, June 1, 2010 9:58:37 PM(UTC)
TurtleCove
Anyone know how I troubleshoot this?
#5 Posted : Wednesday, June 2, 2010 12:57:48 AM(UTC)
Your cold control may have stuck open. I would turn it off and on a few times and spray it with a non-residue contact cleaner.
TurtleCove
#6 Posted : Wednesday, June 2, 2010 10:22:02 AM(UTC)
TurtleCove
Spray what? And where is this "cold control" that you speak of?
#7 Posted : Wednesday, June 2, 2010 11:09:22 AM(UTC)
The control behind the knob you turned.
TurtleCove
#8 Posted : Wednesday, June 2, 2010 11:12:05 AM(UTC)
TurtleCove
well, i hear it clicking fine when I turn the knob...but I'll see if that knob will slide off, and then I'll spray it and see if anything changes....
Thanx.
TurtleCove
#9 Posted : Wednesday, June 2, 2010 11:28:41 AM(UTC)
TurtleCove
Ok, here's a picture of the knob.
When I turn the knob, and the compressor clicks on, the lights dim (flicker) just a bit, which makes me believe I'm getting good contact.
However, the knob slid right off.
Behind it is a plate with 4 screws, as you can see.
Are you suggesting I take those 4 screws out, and the plate off?
UserPostedImage
UserPostedImage
TurtleCove attached the following image(s):
#10 Posted : Wednesday, June 2, 2010 4:30:10 PM(UTC)
Your cold control is fine. Either your compressor is no longer compressing, you have a clogged capillary, or your freon leaked out.
2 Pages12>
