I've read the sticky on the defroster section. What 2 test points to check fpr the ohm reading .I see the orange on pin 9 of the J7 connector but I don't have a " terminal J9 defrost heater"?
Most probable problem is your defrost heater, just remove and test.
Thankyou I'll try that .Seems easy enough to remove.
Thanks for the help.I removed the heater and checked it.Infinate ohms.Took off the end cap and the element was broken ,will order new one.
Very good. I'v learned the hard way to go after the most probable problem, which is usually the easiest to diagnose and repair.
