OnlyOneNurse
#1 Posted : Monday, May 31, 2010 7:52:20 AM(UTC)
OnlyOneNurse
4 year old hard working Bosch dishwasher will not drain correctly. This occurs in both quick and full wash cycles. We checked drain hoses-they are OK. We checked the common drain used for both the DW and Kitchen sinks-they are OK. We discovered that the water will eventually drain if "cancel drain" is selected 2-4 times. A slow trickle can be seen in the drainage tubing which sits under the kitchen floor and above the family room tile. We found some information on the IT to test the controls by pressing power wash and wash at the same time. the numbers that appear are: C2, PO, EO.
Thanks in advance of any direction
Applianceaid
#2 Posted : Wednesday, March 2, 2011 10:58:08 PM(UTC)
Applianceaid
Hello,
This could be due to a clogged drain motor, this is a pretty common issue on these dishwasher, here is a video that explains how to fix this issue yourself.
Bosch DW Repair Video
