bwalker4ww
#1 Posted : Monday, May 31, 2010 7:01:32 AM(UTC)
bwalker4ww
I have a dryer that wont get hot how and don't want to call a repair man how do check to find out what is wrong. ie.: heating element
#2 Posted : Monday, May 31, 2010 7:50:58 AM(UTC)
Replacement parts for WHIRLPOOL LER6646PW1 29" Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576811.pdf
Can be a number of things.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
NOTE: On this unit if the timer advances in timed dry mode it is an indication that you have the 240 volts as the timer motor is wired directly across the 240 volts (L1 to L2) in timed dry.
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 1o ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
If the heater's thermal fuse is blown.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
dryer wont get hot (Dryer Repair)
by 4rgirlz 5/12/2011 12:28:34 PM(UTC)
dryer wont get hot, new element & therm on element (Dryer Repair)
by Thomas Bronte 11/19/2009 6:32:32 PM(UTC)
