I replaced the pump, and still getting the F33 error. I checked the connections and the ccu and everything looks fine. I try putting it on drain cycle and nothing is working. When it originally didn't work, it had 3 mins left and had a heavy wet door matt in the washer, I figured it burned out the motor after seeing it with all the gunk the the trap. Any other trouble shooting suggestions would be great!
