MMegenity
#1 Posted : Friday, July 11, 2008 7:28:35 AM(UTC)
MMegenity
The top element in the oven only works for broiling. When I bake the bottom element heats up, but the top does not. The food remains raw on top and burned on the bottom. The keypad works fine and tells you when the oven is preheated so it does not detect a problem. Can this be repaired with a part replacement?
#2 Posted : Friday, July 11, 2008 5:59:32 PM(UTC)
Your oven works as designed. The upper (Broil) heating element should work only when the Broil mode is chosen.
Put an oven thermometer in the middle of the oven and measure the temperature while the oven control calls for Bake and set for 350°F. Post the result.
MMegenity
#3 Posted : Monday, July 14, 2008 3:04:40 PM(UTC)
MMegenity
Gene,
The thermometer read 300 when the oven stated the preheat was complete at 350.
#4 Posted : Monday, July 14, 2008 5:03:44 PM(UTC)
Try to adjust the oven temperature as described on the page 16 in the "Owners manual".
If it would not help then the control board has to be replaced.
- The part number for the control board (aka clock) is AP2673398
Here are the break down diagrams for the Maytag range Model CHE9800BCB
Electric oven won't bake, when knob is set to bake it tries to work (Oven Repair (including Ranges and Cooktops))
by jcvencill 12/6/2015 12:51:47 PM(UTC)
Jenn Air Range/Convection oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by Pamwest 11/30/2015 11:09:20 AM(UTC)
Upper oven won't bake (Oven Repair (including Ranges and Cooktops))
by stefanino 8/12/2014 8:54:13 AM(UTC)
Bottom oven won't bake (Oven Repair (including Ranges and Cooktops))
by vfrclark 12/6/2013 5:42:20 AM(UTC)
Oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by ConnerNA 9/30/2012 5:05:45 AM(UTC)
by carpool 12/27/2011 10:52:01 PM(UTC)
GE Profile oven won't bake - broil is OK (Oven Repair (including Ranges and Cooktops))
by eric512 12/11/2009 9:23:12 AM(UTC)
Oven won't bake or broil no error showing (Oven Repair (including Ranges and Cooktops))
by jallen 2/2/2009 6:48:53 AM(UTC)
GE Gas Oven won't bake or broil... (Oven Repair (including Ranges and Cooktops))
by ssacrf 6/2/2008 6:13:24 PM(UTC)
Maytag oven won't bake (Oven Repair (including Ranges and Cooktops))
by BestHomes 1/23/2008 10:01:36 AM(UTC)
GE Electric Double Wall Oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by tjp 10/27/2007 8:06:52 AM(UTC)
double oven won't bake (Oven Repair (including Ranges and Cooktops))
by lou 9/12/2007 7:22:12 PM(UTC)
Oven won't bake, only broil (Oven Repair (including Ranges and Cooktops))
by jae 9/5/2007 10:20:45 AM(UTC)
