Groups ready for retrieval: Registered
[FONT='Times New Roman']When the start button is pushed the motor runs as long as the button is held down. Releasing button results in motor stopping. The heating element does do heat while holding the button down. I have checked continuity of the heating element, High limit Thermostat, Thermal Cutoff, Thermal Fuse and Thermistor. All have continuity. Any suggestions of what to check next?[/FONT] [FONT='Times New Roman'][/FONT] [FONT='Times New Roman']Thanks[/FONT]
The problem with your dryer is a bad control board inside the control panel. - The part number for the control board is AP3094289 Gene.
