AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Sounds like small rocks rattling inside drum when spinning
2002 Model, I have taken the back off down to where i can see the bearings. When I manually spin it, it sounds like there are rocks tumbling inside the tub. Are there bearings also on the inside of the tub that could be bad. If not, what could be causing this? Any help would be appreciated.
Sounds like the rear bearing (which is coming together with the rear outer shell) gone bad as well as the inner tub support. To replace both of this parts is very serious job which will take 3-5 hours. - The part number for the outer shell and bearing assembly is AP2578105 - The part number for the inner tub is AP2107258 Gene.
Washer Repair
