Replacement parts for FRIGIDAIRE MRS22WNGW6 Frg(v2) / Refrigerator | AppliancePartsPros.comCan be a number of things, below are the most common.
If all the below are OK then it could be the main thermostat. Check the freezer temperature should be around 0 degrees F.
First is the evaporator fan in the freezer running?
It is required to push cold air into the fresh food section.
Next be sure the vents between the freezer and frsh food sections are clear of items.
Next is the damper (Item 115 in Section 5) between the freezer and fresh food sections open.
Next remove the evaporator coil cover inside the freezer and check the coils, if they are heavily iced/frosted over you have a defrost problem. This is often noticeable in the fresh food side and later in the freezer side.
Checking a defrost problem
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 23 in Section 5) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
