Hello, this is a gallery pro. series, 10 years old. Model FRS24ZSG. The water dispenser and ice maker only gets a dribble of water. I checked for water pressure and clogs up to the first valve including the screen and all was good. Replaced filter also. When I activate the in the door water dispenser I hear a "pump" running but get a drip/dribble of water. Should I replace the first valve? Or is their a cheaper fix? Thanks.
