My maytag machine gets to the ten minute mark starts to drain than stops and starts filling up with water again and goes back to 18 minute mark and starts the rinse cycle again. anyone have this happen and know what the problem is? Thanks in advance!
I would start by running up the Quick Spin test on page 14 of the Service manual.Enter into Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”Make sure you can Spin up to 850RPM. Start a Spin Only cycle with the wet load with Max Extract selected for the Spin Cycle. While in the Spin Only cycle enter into Service Mode and watch the max RPM achived. Did you reach 850RPM? If not what was the max Wash Basket RPM reached With no error codes to the LED display that is where I would start. Maybe the Outer Tub bearings are dragging. Do you hear any excessive bearing noise when you Spin up the empty Wash Basket?If you open the washer lid and rotate an empty Wash Basket CCW as fast as you can. It should continue to rotate several times and coast down to a gentle stop does it?You can drain the Wash Tub in Service Mode here is the process; Go to page 16 of the SM lower right hand part of page Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop the pump with the off button or hit the Presoak key.
Have you ever had an unbalance error code such as dC or uC in Spin Cycle?
Post back if you have questions/concerns I’m an owner and will try to help you.
Dick
