jpw050
#1 Posted : Monday, May 24, 2010 6:22:07 AM(UTC)
jpw050
I have a Maytag electric dryer, Model #LDE882. It is noisy when first starting to dry clothes and turning the drum. I opened the unit, front and rear. The noise appears to be coming from the part shown in the parts diagram as PULLEY-ID. The drum belt appears to be okay.
Does this pulley wear out? What other parts should be replaced if replacing this pulley? If anyone has a repair manual for this dryer, I would love to take a look at it.
Here is the part information from the parts diagram on AppliancePartsPros.com
PULLEY- ID
Part Number: AP4372890
Made by WHIRLPOOL
Read more: http://www.appliancepartspros.com/part_details.aspx?part_id=4372890#ixzz0or6iSajm
Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
#2 Posted : Monday, May 24, 2010 7:16:55 PM(UTC)
Try to lubricate it.
jpw050
#3 Posted : Tuesday, May 25, 2010 11:21:48 AM(UTC)
jpw050
Should I use something like a white lithium grease or a spray such as WD40?
#4 Posted : Tuesday, May 25, 2010 2:24:46 PM(UTC)
I would use any kind of a car engine oil (even used one) - just 2 or 3 drops.
