mrides
#1 Posted : Tuesday, July 8, 2008 9:02:25 AM(UTC)
mrides
my dynasty 48" oven/ broiler will not ignite. when the power is switched on and the common thermostat placed on a temperature or the broiler setting, both glow bars turn red but no ignition occurs. i replaced the oven gas valve with no change. since both the oven and the broiler quit working at the same time and the ignitors both glow i suspect the problem may be in the thermostat. any suggestions would be appreciated. also, any information regarding a source for dynasty replacement parts would be appreciated. thank you.
mrides
#2 Posted : Wednesday, July 9, 2008 9:57:57 AM(UTC)
mrides
on a hunch i replaced the oven ignitor. the oven ignited in the normal fashion. i will replace the broiler ignitor soon and hope the entire problem will be resolved.
Whirlpool Oven/Broiler won't light (Oven Repair (including Ranges and Cooktops))
by 67cutlass 2/27/2015 4:51:59 AM(UTC)
GE XL44 Oven/Broiler Won't Light (Oven Repair (including Ranges and Cooktops))
by lprice1024 1/20/2012 4:44:57 PM(UTC)
