Stored this unit 2 months then installed, Now the motor hums but does not pump. Gets REAL hot as well. How the heck do I pull the darn pump to get to impeller. My Lady is nearly postal..HELPPPPPPPPPPPPPPPPPPPPPPPPPPP.
For the record...it's not the hose or drain line...both clear. I also checked the screens and the inner sump area for junk...Crikey!!!!!:eek:
Thanks in Advance..I might survive another day if someone could help me... Mark Chestertown MD
Hey Folks...anyone Care Too Help??????????????????????????
Well guys...guess you pro's knew I would search the old posts...THANKS for well..not replying. The solution was as follows: Take 1 friggin screw out of the right side facing the front...rotate the JAMMED motor...put all the covers back on..runs like a charm. Food must have jammed the pump motor. The selinoid was humming trying to push motor I guess. Great washer btw...
