John M Sanders
#1 Posted : Sunday, May 23, 2010 3:02:53 PM(UTC)
John M Sanders
My son's whirlpool dryer quit working. I tested the breaker, plug, door switch, start button and all are working properly. When I set the timer to run, push the start button, nothing happens. (the door is shut and I can hear that the timer motor is running) At this time I tested for current running thru the 2 larger red wires running to the wire harness at the bottom of the motor and there is current present, which leads me to believe that the motor is bad. However, I did not check the overload device, if the overload device has tripped, what does it shut off? The motor, the heating element, the timer, or does it shut down everything? If the motor did fail, and the heating element remains on, wouldn't the overload device shut down the element? I understand that the overload devices cannot be reset, only replaced, is that right?
So I estimate that either the motor or the overload device, or both are defective. If I eliminate the overload device, then it must be the motor.
Right? And if I replace the motor, which model? My dryer is approx 9 or 10 years old, and when I put in the model number, the replacement motor comes up at part #2584. But the description says that that motor fits all dryers prior to 1996. The dryer is not that old. How do i determine which is the correct motor?
Thanks for any and all help. My son has 6 kids and the laundry is piling up!
#2 Posted : Wednesday, May 26, 2010 4:23:36 AM(UTC)
Replacement parts for WHIRLPOOL LEB6200KQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406692.pdf
[COLOR="Blue"]
My son's whirlpool dryer quit working. I tested the breaker, plug, door switch, start button and all are working properly.[/COLOR]
How did you check the voltage?
It should be
L1 to L2 240 volts.
L1 to Neutral and L2 to Neutral should both be 120 volts.
Note that the motor only uses 120 volts, the heater requires the full 240 volts.
I am assuming you checked the door switch and the push to start using ohms with the unit unplugged. Also did you remove the wire from at least one side of the device you were measuring. Thjis ensures that you do not read an alternate/parallel circuit path.
[COLOR="Blue"]At this time I tested for current running thru the 2 larger red wires running to the wire harness at the bottom of the motor and there is current present, which leads me to believe that the motor is bad.[/COLOR]
The large red wires are usually the heating coil and it should not have current flow unless the motor is running due to the centrifugal switch on the motor.
Could it be that you are confusing current with voltage?
It is normal to have voltage here.
[COLOR="Blue"]
However, I did not check the overload device, if the overload device has tripped, what does it shut off?[/COLOR]
This would be at the top of my list (Item 7 in Section 3).
It kills power to the motor.
Note the unit has 2 thermal fuses but the other one is near the heater assembly and just cuts power to the heater.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
[COLOR="Blue"]The motor, the heating element, the timer, or does it shut down everything?[/COLOR]
With the fuse blown the timer will run in timed dry, the motor will not start and this will also kill the heater. The motor has a centrifugal switch on it. This switch closes when the motor gets close to operating speed closing the circuit to the heating element, it ensures that the coil does not heat up until you have air flow.
[COLOR="Blue"]So I estimate that either the motor or the overload device, or both are defective.[/COLOR]
Probably just the thermal fuse.
[COLOR="Blue"]If I eliminate the overload device, then it must be the motor.
Right?[/COLOR]
I would do more trouble shooting first.
RadCadDad
#3 Posted : Monday, May 31, 2010 3:37:47 PM(UTC)
RadCadDad
This sounds very much like what just happened to my with my Whirlpool
lec6848aq1 electric drier
Turn the timer on, you hear it running, hit the button and you feel the button wanting to do it's thing, but, nothing happens. Button reacts differently with/without the front door switch depressed, as expected. the difference (I'm assuming) being power/no powerr being supplied.
My question here would be, when you state the following:
"Remove both wires from the fuse, short them together and tape them up so they will not short to the frame."
The wiring diagrams I'm finding (including the one internal in my unit) do not match the wire colors I'm seeing.
Where would these wires be found, and in what location on the drier? (under the top console, or behind the rear panel)
I 'did' find what could be a possible fuse (mounted to the rear wall) with 2 blue wires to/from it, down behind the rear access panel.
~chris
#4 Posted : Monday, May 31, 2010 4:20:47 PM(UTC)
RadCadDad
Please start your own thread using Post New topic in this section.
Different model numbers in one thread can get confusing.
If you look up the model number in the parts section of AppliancPartsPros, it has a parts breakdown. The thermal fuse I am referring to is on the back of the blower (Item 7 in Section 3)
Wiring diagram does show a Blue wire to one side of it, wire color is not given for the other side.
