braunchad23
#1 Posted : Saturday, May 22, 2010 7:31:13 PM(UTC)
braunchad23
My washer fills up with water but then does not agitate, spin and does not drain. You can see it try to spin and then it stops. Since it does not cycle it will not drain either. Please give advice, will try anything.....
#2 Posted : Sunday, May 23, 2010 2:53:09 AM(UTC)
I would look for a sock stuck in the water pump.
braunchad23
#3 Posted : Sunday, May 23, 2010 6:32:00 AM(UTC)
braunchad23
how do i go about taking this washer apart?
#4 Posted : Sunday, May 23, 2010 7:30:08 AM(UTC)
Go to www.applianceaid.com for info on this direct drive washer.
braunchad23
#5 Posted : Sunday, May 23, 2010 8:42:49 AM(UTC)
braunchad23
I got it. It was a detergent/dryer in one sheet not allowing it to drain. Guess we wont be using them anymore. Thanks!!
