dsadosky
#1 Posted : Monday, July 7, 2008 1:27:16 PM(UTC)
dsadosky
Over the weekend my SxS Frigidaire refrigerator stopped working. The unit is still getting power as evident by the lights inside the unit.
If I turn the temperature switch in the freezer to off and then back to the correct setting the unit begins to cool again. The unit runs for several hours. Long enough to begin freezing a bowl of water and then shuts off. While running, the compressor is warm/hot to touch and the fan is working normally.
There are no unusual sounds coming from the unit. It simply doesn't cool. Any help would be appreciated.
#2 Posted : Tuesday, July 8, 2008 12:35:24 PM(UTC)
Most likely the problem is a bad temperature control (#21 on the break down diagram).
- The part number for the temperature control is AP2145312
Here are the break down diagrams for the Frigidaire refrigerator Model FRS26ZSHB0
Albeto
#3 Posted : Tuesday, October 13, 2009 8:22:51 AM(UTC)
Albeto
Mr. Gene thanks for helping...I have the same problem with frigidaire model FRS26ZPHW1. A guy came an took a look at it... told me same thing it was the temperature controler AP2145312... so I am going to order it an put it myself... thanks again Mr. Gene.
#4 Posted : Tuesday, October 13, 2009 4:50:40 PM(UTC)
