zakyak
#1 Posted : Monday, July 7, 2008 11:42:34 AM(UTC)
zakyak
When we press the bake temp button to turn on the oven the message is "off". Does that mean the controls are shot and need to be replaced? An electronic clock control panel for the 30-4980-32/03 looks the same as mine, will it work?
thanks
#2 Posted : Tuesday, July 8, 2008 12:12:25 PM(UTC)
Most likely the problem is a bad control board (aka clock). Unfortunately this part is no longer available.
Eug28
#3 Posted : Thursday, February 5, 2009 12:56:43 PM(UTC)
Eug28
Frigidaire PN 5303269513 Electronic Oven Control/Clock-Timer is NLA. Does anyone repair the faulty part or have a good one still in stock?
Eug28
#4 Posted : Thursday, February 5, 2009 3:40:55 PM(UTC)
You can try PCBR.
gene.
Tappan gas range (Oven Repair (including Ranges and Cooktops))
by maryjanefultz 7/28/2013 12:32:42 PM(UTC)
by dw56 8/16/2012 5:17:58 AM(UTC)
Tappan gas range acting strangely (Oven Repair (including Ranges and Cooktops))
by andrin77 3/11/2011 10:16:05 AM(UTC)
Tappan Gas Range (Oven Repair (including Ranges and Cooktops))
by soulfoniclady 1/1/2008 10:03:29 AM(UTC)
