AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Frigidare gas dryer runs but no heat or ignition
This is a Frigidare FG041AC1- also tag of electrolux found. It runs and gets to speed but there is no heat. I watched the burner and did not see a glow or an ignition. The exhaust and Intake vents were clear, no blockages. I checked the thermostats these had continuity. Mechanically seems sound runs quiet and smooth. I appreciate you help. Thank you Hanzi
Hanzi,
The model number you posted does not come up. Is it an American model? Verify and repost it.
Dryer Repair
