AppliancePartsPros.com
Appliance Repair Help
Washer Repair
My washing machine fills with water, but that's it
My washing machine fills with water, but that's it; it does nothing else. The timer does not advance after filled with water or make any noises if i advance the timer to spin, its drain out water but no spinning. Thanks for your help
You'll need to check your door switch, sound like it may be bad.
yes , it is door switch one on the wire was disconnected. How can I remove door switch?(take it out) Thank you!
Washer Repair
