Freezer stopped making cubes, lots of frost, & refrigerator side not cooling any longer. had water come out under freezer, dried that up, unplugged it, next day plugged it back in and it worked for another week & started the whole process over again, now it's frosted & not cooling the right side anymore!
its either your defrost timer, bi-metal or defrost heater.
thanks, over the weekend, I pulled it out vacumed and cleaned it very well, plugged it back in when all the ice was completely gone 24 hrs! not it is working, hopefully for good, if not I will check out those parts you recommended! thanks again Ps.. I think the drain pipe was clogged too, hopefully it will keep running & working
